Online: Retroman, Hilly
Screamin Eagle Tuner Map for Woods 222
  • brettm357
    brettm357
    I have a 2013 Fatbob with SE Air Filter and Vance and Hines Short Shots if i wanted to fit Woods 222 cams to it but only have a Sreamin Eagle Pro Tuner what map should i use before sarting smart tunes  - Closest Dyno to me is 700kms
  • locks
    locks
    Gday Bret, try 358SCV002, it has the closest cam timing events to the 222's, will need some work to make it suit your bike though.
  • brettm357
    brettm357
    What would i need to setup before i start running smart tunes
  • locks
    locks
    Nothing that I can see, it's a 103 cal, injectors are right for your model, by set up I ment getting the VE's dialed in ie smart tuning, are you up to speed with the process?
