Online: speedzter
headlight
  • carcano
    carcano
    Hi can anybody give me some info on beefing up the brightness in my headlight for a 2012 Switchback ive been told about the daymakers but the cost is a bit over the top for my pocket i all so heard the peripheral vision is not to good. the thing is with a Switchback is you just can't stick a bulb in them due to the wiring. Any help would be greatly appreciated.
  • thereyougo
    thereyougo
    A 90/100w or 100/130w should brighten things up a little.
    When you say 'due to the wiring',do you mean you cant get it out or current limitations? Because the spring that holds the globe in unhooks from the loop , gotta loosen the screw sometimes.
    http://www.narva.com.au/products/browse/halogen-performance
    I've got a Daymaker on my Breakout, yes expensive but there isn't anything really like it, very intense daylight comes out of this sucker. If peripheral vision is the problem with one just get two, easy!
