Online: speedzter
front turn signal relocation?
  • 666
    666
    hey just wanting to know the ins and outs of doing the relocation on 2012 wg off the bars down to the triple trees any info pics would be great cheers
  • Evo
    Evo
    Triple trees or fork legs??
  • Methuselah
    Methuselah
    Yep, fork legs is the easiest way, you just but a kit to mount them on your forks. The mount is in 2 parts so you don't have to take the forks off to get the mount on. I just pulled the mounting bolts from under the mirrors and replaced them with a chromed dome nut. If you have the standard mirrors you've got to shorten the thread shaft other wise it is too long to fit a domed nut, for aftermarket mirrors they fit straight on. Either side of the forks meets the distance apart from each other regulations.
  • 666
    666
    Yep will be the same set up as yours what about electrics mine are through the switches then through the bars do you have to pull them out? Or is there a connection down lower on the loom? Cheers
