Online: John.R, DIVOT
CTEK MXS 5.0 CHARGER
  • hoodyroo
    hoodyroo
    Anybody had any problems with HD factory alarm whilst on charge
  • Arron
    Arron
    Havn't had a problem with my 2013 Street Bob when on charge and i regularly have it hooked up to a CTEK MXS 5.0.
  • FatboyMac
    FatboyMac
    I use that same model charger on my 09 Fatboy & never had any issues.
    The factory alarm/security works as normal Mark, I use the HD trickle charger.
  • fat55
    fat55
    I use it with no problems
  • markwoumla
    markwoumla
    Thanks allde ,,, But my question was to the OP ,, (should have explained it better) ,,, Seems like he is having some sort of problem with the alarm/security system while bike/battery is hooked up to a tenderer !!!! Other wise , why ask the question !!!!
    One problem I ran into, was, when disconnecting and connecting battery, and switching ignition on and off a few times , I inadvertently switched the chirp mode from enable to disable .. ie, turn signals flashed,, but no chirps, (security system is still enabled in the chirpless mode )...
  • hoodyroo
    hoodyroo
    noticed alarm light not flashing unpluged charger pushed fob nothing happened no chirp no flash, turned ignition on all seemed ok started fine stopped pushed fob again very faint flash and a very sick chirp left over night flash good chirp good no probs dont know what happened
