Online: Wanderer57
Please check defect on it
  • Jaycee
    Jaycee
    Hi, guys. Can you find defect on it? Do you guys think this BO will be defect magnet?
    I am thinking weld extended mudguard numberplate which is stock with this fender.
    Also, exhaust made quite as stock.
  • steelo
    steelo
    Not that I mind the look but why the engine bar?
    I doubt those exhausts are as quite as stock, no rear brake light or indicators, no Rego plate and the rear mud guard stops way to early.
  • blueystar
    blueystar
    You need glasses allde I can see them
  • beaglebasher
    beaglebasher
    HEADS UP. I think J might be another troll. Whats a BO   J?
  • Jaycee
    Jaycee
    Breakout??
    I always thought BO was body odour. Whether this bikes in Korea or Sydney (which has turned into Asia), it ain't roadworthy. Fender, lighting, plate, exhaust.
  • Muscled_up
    Muscled_up
    I think the guard is now legal as the adr regulations changed
    Your guard only needs to be a length of 90Deg to the rear axle now
  • Squid83
    Squid83
    You can change those indicators to have both red and Amber lights for stop and indicator combined. Don't know if it's make it legal where the idicators now sit but it'd be a lot more close to passing then the current brake light setup
  • FXST11
    FXST11
    Indicator needs to be seen from both sides. and I think maybe to close to ground. Definitely Plate & Brake / tail light. as plate must be seen from a 45% angle from ALL directions.
  • Jaycee
    Jaycee
    Yes. It is in Korea. Is it looks ugly?
  • Jaycee
    Jaycee
    I'm thinking modified be like this.
  • Jaycee
    Jaycee
  • Jaycee
    Jaycee
    Yes. I will get it on follow Monday. I had 48 and trade it.
  • johnnybegood.
    johnnybegood.
    i like the look of it, if u r in victoria it will be a defect magnet, the side mounted  stop light and number plate they go sick over, may or may not be legal but ait aint worth the hassle
  • Cartoon Head
    Cartoon Head
    Why would you take a Breakout and fuck it up like that?
    It almost looks like they have tried to turn it into a Rocker C.
