Online: Retroman, Hilly
Whats your favorite bike cleaning products ?
  • AlHD48
    AlHD48
    Hi Guys
    Was wondering what you find are the best bike cleaning products that give a showroom finish ?
  • Drac
    Drac
    The best spray on detailer I found is Lusas slick mist.
    As good as or better than mister sheen and it is not silicon based and can be used in the sun.
    For the Aluminium  - Purple Polish
    For the Paint - Mr Sheen
  • fat55
    fat55
    Meguirs quick detailer , great product , chrome paint just about anything on the bike
  • graeme
    graeme
    glass cleaner for chrome
  • Nomada
    Nomada
    Mr Sheen on almost everything
  • Harry28
    Harry28
    Soapy water and a sponge every 3 months.. Lovelyyes
  • chopa
    chopa
    purple polish and m - Ron Glass and Meguirs quick detailer in between
    If your short on choice, this crowd are located in Melbourne:
    http://www.waxit.com.au/
  • Methuselah
    Methuselah
    Bowdens Show Car shine wax and Meguiars quick detailer in between.
  • Damage
    Damage
    CT18 truck wash and a hose
    Elbow grease! ya can't clean anything without it!
  • DR
    DR
    + 1 for Mr Sheen on almost everything
  • Riggers
    Riggers
    Do you use Lusas on a dirty bike or a washed bike? Seems more like a polish/wax more than a cleaning product?
  • Drac
    Drac
    Lucas slick mist is just a detailing spray which can be used on any surface.
    My paint is ceramic coated and doesnt need waxing so any good car wash and the slick mist is all i need.
    I used to use mister sheen until a couple of auto painters told me not to because it is silicon based and not wax and gives no protection from the sun.
