Online: Merv
06 dyna Street bob
  • Heathbru
    Heathbru
    G'day all , I've recently instaled V&H big shots onto my Bob which is stock . I have also purchased a super tuner pro which is next to useless for me as the bike doesn't have the 02 sensors which means i cant use the smart tune function to tune my bike. The calibrations (maps) from HD give only 2 options for maps and both are pretty stock maps which brings me to ask if there is anywhere i can get a map to suit my bike or do i have to take it to a dyno?
  • locks
    locks
    gday mate, if your pipes have 02 ports in them you can buy the sensors and plug them straight into your wiring loom as the wiring for them is all there already, the yank bikes were fitted with 02 sensors but not ours, the front connector is behind the regulator and the rear behind the battery box, got to pull the box off to access it, sensor part number is 27683-06, you need two obviously, I did it to my 06 dyna and I have done it to other 06 dynas as well, if you do this you will have plenty of Calibration choices and you can dumb tune till your hearts content, hth.
  • Retroman
    How old is your Streetbob and where in Australia are you ?
  • Heathbru
    Heathbru
    Thanx guys for the super quick replies . Its an 06 Street bob that i picked up just recently (8 years old and only 283 KMS on the clock) and got it at a second hand price .
    I live in Traralgon , latrobe valley vic. Thanx again for the quick replies as it was doin my head in.
    Hey Locks , were did you get the 02 sensors from and are there any other parts i'll need? cheers in advance.
    You buy the O2 sensors at the dealer. There may or may not be aftermarket ones available but it would be best and easiest to just buy from the dealer. I think it cost me around $60 for the pair last time but don't quote me
  • locks
    locks
    As Fatbat says and no that's all you will need for your 06
