Online: beaglebasher, John.R
Help me find some integrated taillight/indicators
  • noctm
    noctm
    G'day all,
    One of my stock rear brake light/indicators has stopped working (well, the brake light not the indicator itself). I tested the connection where it plugs in under the seat, and all is good on that end, so I think the issue is within the unit itself which is sealed and I can't be fucked playing with it. So with that being the situation I am looking to replace the set.
    Problem is I can't seem to find any sets of integrated brake/turn signals. They're either brake lights or indicators and that's it. I'm assuming that's because in the states they're not integrated in the first place and that's where most of these aftermarket parts are going.
    Anyway is anybody able to point me towards some half decent integrated brake and turn signals that would fit my bike (2011 XLN) that aren't HD OEM?
    I know I could just get a replacement through HD but I am looking to get something different if I'm going to be replacing them anyway.
    Only after black ones, no chrome.
    Cheers.
  • Stel
    Stel
    I run these on my 2013 Sporty
    http://www.kuryakyn.com/products/4843/torpedo-lights
    You might also check these out
    http://www.hightechspeed.com/products/XARC/index.asp
  • noctm
    noctm
    Thanks guys. Some real nice options there. I fucking struggled to find any half decent ones - obviously not looking in the right areas.
    If anyone else has some to suggest keep em coming
    I sell these for $100.00 each [URL=http://s258.photobucket.com/user/raced86/media/IMG_2160_zpsnqqqerv5.jpg.html][/URL]
  • noctm
    noctm
    Cheers Walka. I actually stumbled upon them on MCAS but they only have chrome ones, do you have black ones by chance?
    Only Chrome
  • noctm
    noctm
    Ah okay no worries mate thanks anyway.
    EDIT: I have ordered some of the black Kuryakyn Torpedos. Seemed like exactly what I was after. Cheers all for the help.
