Online: conmore
after market headers
  • Steve L
    Steve L
    tossing up between RC Components RCX Chrome True Dual Headers and Vance and Hine true duel headers. The RC are over $100 cheaper, doers anyone on here have them. I have a set of Supertrapp mufflers to go on them.
    Hi Steve. Where did you get your supertrapp mufflers from and what made you choose them? I like supertrapp exhaust stuff but not too common here.
  • Steve L
    Steve L
    got them off ebay 2nd hand and they were cheap at $300. The reason I like them is because you can easily change the sound by changing the discs.
    You got a good deal. I like em for the same reason. And they're not obnoxiously loud despite flowing really well
  • Steve L
    Steve L
    vance and hines pro pipe
  • Steve L
    Steve L
    ended up buying Vance and Hines dresser duals
  • Outcast
    Outcast
    What is the advantage of the true dual header setup vs the 2 - 1 - 2 setup of the original headers.
    I've got a pair of Monster Ovals coming that I found going cheap on Gumtree but, will initially install them onto stock headers. Curious what is to be gained by going to duals..
    Also, what is the difference between the dresser duals & the power duals?
  • Steve L
    Steve L
    the after market headers flow much better, have a look at your cross over pipe plus the stock also have a very restrictive cat in them. The dresser headers are a cleaner looking header where as the power duals have a chamber to supposedly help power. Best is to look them up to see what I mean. If you change headers you will need to get it dynoed.
  • Outcast
    Outcast
    Cheers Steve & Tim
  • Steve L
    Steve L
    yeah Tim that's them and looking again at the pic of the power duals I'm glad I went with the dressers.
  • Steve L
    Steve L
    I got mine from Easy R in Brissie but Walka from here also has them and he does them for a good price. Not sure on model number but just tell him what year your bike is.
  • Krackers60
    Krackers60
    Thanks Steve.
    When I'm ready I'll speak with Walka who is not far away from me.
