Saddle Bags
  • Templar Knight
    Templar Knight
    I'm looking at fitting saddle bags to my 2005 Dyna Super Glide, from what i can work out i need to move the rear turn signals. Does anyone know the best place to get bags and brackets from and do i really need to move the turn signals or is there bags that fit around the shockie ?
    Cheers, BJ.
  • FXDF08
    FXDF08
    Original HD brackets work with orihinal indicator location. Perfect fit, simple installation ( do it yourself ), but might be a little more than some after market. The HD brackets on my FXDL worked perfect and were worth the money. Search for Kazz Mazz leather bags. Again, cost a little more, but last saddle bags you ever need to buy.
  • Aaith
    Aaith
    if you dont want to move the signals you can get the fox creek dyna low ones.
    https://www.foxcreekleather.com/products/86-dyna-low-rider-saddlebags?display_category_id=287
    there was a guy on youtube that did a vid review of them and they fit in nicely...
    https://www.youtube.com/watch?v=jYoUz_teJ74
    I would have already purchased a set but im not in the good books at the moment with the Minster of war and finance
  • Templar Knight
    Templar Knight
    Cheers Aaith, I will go check it out :)
  • FXDF08
    FXDF08
    Yeah Kazz Mazz work perfectly with HD brackets and indicators stay in thw same spot. Brackets come with new spacer for indicators. Havent got photosnon this device, but will try and remember to post in next day or so. Surs HD website will have a photo???
  • Templar Knight
    Templar Knight
    Cheers FXDF08 :)
