Online: beaglebasher, John.R
Wide glide and Power vision
  • Theironbear
    Theironbear
    Hey Guys,
    Just wondering if anyone on here has had much experience with the Power Vision tuner? I did a search but it only gave me older results. Tossing up between the super tuner and the powervision. I like the idea of the on the fly tunes and ease of use with the power vision.
    any pros and cons?
    Thanks in advance everyone.
  • Aaith
    Aaith
    I went the power vision...
    1. on a mac so.... windows pc.. hooked up to bike with the tuner seemed so old fashioned (like the tuneboy i had on my old triumph)
    2. you can marry the power vision to multiple bikes (just have to buy a extra ecu key... at an extra $150 or so)
    3. was simple and self contained but the fact that if i go crazy and do cams it can do it where the Vance and hines one couldn't..
    cons... its $$$ but you don't have to pay for the tuner and a cable...
    you have to have it somewhere if your doing the auto tune runs... (may be easier to snake the cable of the super tuner in your pocket than this thing)
    I have a powervision and think thats its easy to use as well as the auto tune is usefull
  • Drac
    Drac
    I just unlocked mine and the cost was about $350 plus gst.
  • Drac
    Drac
    I tried applying on the web site and nothing happened so after about a week I contacted them and they told me that I had to go through Aussie distributor and they had forwarded my request to them. Another week later, still nothing. I contacted them and they said that I had to go through my local approved supplier. I rand Fred at Procycle dyno and he had to wait a few days to get new keys. I took the tuner to him and he set it up and charged me cost plus gst.
    Still cheaper than a second unit I guess.
  • Aaith
    Aaith
    Dam Just double checked
    $199 unlock... well at least its cheaper than a new one
    http://www.dynojet.com/powervision/powervision-tune-license-programs.aspx
