Online: John.R
How many spokes are standard on a 2015 street bob?
  • Alpha Male
    Alpha Male
    I am trying to replace my rear rim with a 17" x 6.25" spoke wheels but I have no clue what sort of spoke wheels our 2015 has got. The reason why I am going with 17x6.25 is because it will fit 200mm rear tire without having to mod the bike and 200mm is exactly what I want. The website sells 60 spokes all the way to 120 spokes rims.
    Thanks guy and gals in advance.
  • Alpha Male
    Alpha Male
    What do you guys think of this rim? It's made for a street bob 17" x 6.25" and will fit a 200mm rear tire without modding according to this website wheel table guide:
    http://www.hdwheels.com/product.htm
    I want to buy this rim but unsure if my current front one is 100 or 120 spoke rim, i want to make sure this rear rim i am replacing will have the same amount of spokes on the front.
    http://www.hdwheels.com/images/80-100-120_Spoke/Wheel120High/17x6.25%20120%20Apollo%20Cross-Radial%20Pol%20Twist%20and%20Black%20Spoke%20Black%20Rim%20and%20Hub.jpg
    Does anyone know if my front one is 100 spokes or 120 spokes rim?
    Thanks in advance.
  • Daggs
    Daggs
    stock wheels have 40 spokes, is yours stock? why can't you just count your spokes to make sure? don't you have your bike there with you?
