Online: Soapbox2627
powdercoat v paint ?
  • hdbloke
    hdbloke
    Im about to get a frame painted  and the question in my head is powder coat or paint , this is a kraftech frame that hasnt got old paint on it . So either way you go which is the best place nearest to Newcastle ?
    2 pack , my 2c worth .
    Powder coat is all I have ever done on my jap bikes two Harley frames and a Kraftech most powder coaters
    Sand blast it any way so it's clean anless it's chrome and if that's good thay go straight over the top
    And it's cheap to get done you will have to clean up wear there is any bearings run or bolt threads
    And also blow out any excess sand out of the frame  you don't want that staying in there and getting wet latter on
  • hdbloke
    hdbloke
    think its going to be powdercoating the frame is the way im going to go ,  just have to find someone thats done a few bike frames i think is going to be the key
    In both cases look at getting the frame phosphate plated before coating, ask anyone in the industry and most will do this first.
  • SoftailSteve
    SoftailSteve
    doing a resto on a jap bike. sandblasted frame then 2 pack paint.looks good was going to powdercoat but easier to touch up paint if needed
    The company that you use to powder coat or paint your frame, should be able to do it themselves or know of a company that can do it for them.
