Online: beaglebasher, John.R
Anyone use earplugs
  • AlHD48
    AlHD48
    Hi all ,
    Does anyone use ear plugs when they ride ? What do you use ?
    Pardon did not hear you, what did you say?........smiley
  • AlHD48
    AlHD48
    Lol
  • 92Fatboy
    92Fatboy
    only on a trip i use the foam ear plugs , the $2 ones which seem to work fine.
    I use earmould.  Google them. I run the ones with headphone lines that contain speakers piping music or gps to my ears. Plugged into my iPhone. Perfect
  • Wimbo
    Wimbo
    I use the $2 ones on long journeys with goggles and Open Face.
    Otherwise I like to hear the traffic. I don't use an Ipod as when I feel like listening to music, I sing. I really like my singing.
  • Soapbox2627
    Soapbox2627
    I have 3 or 4 pair in my jacket pocket yet have never remembered to put them in.
    I do have speakers in my helmet from the Scala, I also listen to the I-Pod and take phone calls.
  • Geoff3DMN
    Geoff3DMN
    I use the disposable foam ones on longer trips (when I remember to), they work fine as long as they are something like the right shape for me (some types I find a bit long).
  • boxa
    boxa
    I use the cheap ones , but the little barrel shaped hard ones ,, the longer ones i find did'nt go in the ear proper so i cut them in half a couple of times , that made them go i easier , but a bit too easy , i lost them , then had to go to the docs for him to get them out ,, and just because i always learn i done it again .
    So now i only use the barrel shaped harder ones .
  • Methuselah
    Methuselah
    I use Uvex X-Fit, they are comfortable and can be re used a few times.
  • Damage
    Damage
    Every time, every bike. just the cheap work issue foamies.
  • chriso
    chriso
    Earmould for me
    http://www.earmold.com.au
  • DR
    DR
    I use the cheap foam ones all the time, works fine for me.
