Hi All
has anyone had a heat shield clamps break fron the heat sheild?
That has happened to my short shots front pipe, closest to the front wheel.
does any one think i can get it welded back on ? a new one cost $260 dont really want to spend that much on a heat shield.
advice is appreciated ,
thanks
