Bought a CVO Softail from VIC.
I plan to use the remaining 6 months VIC rego before doing the SA check.
Currently have V&H Big Shots on the bike.
Do ALL Softail standard pipes fit my 110?
Can borrow late model pipes for the test.
Just making some enquiries for you myself Ralph.
If you get the WHOLE SHEBANG, headers/Mufflers/brackets/balance pipe AND frame brackets and bolts , then any Heritage/Softail Custom/Nightrain/Softail Standard system will fit The 07 and 08 CVO Springers had an exhaust that from stock was more similar to a Fatboy / Deuce system , with model unique mufflers. ( And only the 2007 Deuce , a very rare beast in Australia !) You can't use earlier than 2007 , nor later than 2010 , because of the size and position of the O2 sensors The Rocker system will NO WAY fit , so don't go there , same goes for the stock 2009 CVO Springer System
