Online: Humbug, Hilly
6.5 Boom box GPS hidden features.
  • Chaser
    Chaser
    GPS is actually not a true indication of speed and depends on the terrain.
  • grahamjb
    grahamjb
    China
    So you are saying that your Boombox indicated speed and speedo both show 113 kmh and the iPhone TomTom app shows 110kmh?
    Have you compared the Boombox/Speedo indicated speeds with an actual aftermarket GPS....not the TomTom downloaded app on your iPhone?
    The iPhone does not display direct received GPS data and relies on a data connection from either wifi or a Carrier to display the location/speed data that is calculated by triangulation from nearby Carrier base stations where fixed GPS receivers are located.
    I will do a test this weekend to see if I get similar results.
  • grahamjb
    grahamjb
    I stand corrected China and was not aware that the more recent phones use GLONASS plus A-GPS and not A-GPS only, which is what I was referring to - thanks for the clarification.
    Re the Boombox GPS speed and the speedo speed being linked, do you know if anyone has disconnected the speedo signal from the speed sensor as a quick way to confirm this?
  • grahamjb
    grahamjb
    Double post GRR
