Online: John.R
Bassani 2 into 1
  • chriso
    chriso
    They are a good quality pipe
  • brash
    brash
    Bobcat? It's supposed to be very good.
    I'm running the Pro-street 2-2 and it's excellent, good build quality and sounds the goods, just don't get the performance gain as a good 2-1 would get but oh well :)
  • Ranga
    Ranga
    I bought a Bassani 2-1 for my Dyna. I was very unimpressed.
    The quality of the Chroming was very poor and I was not convinced by some of the welds.
    Heat shields were unavailable.
    The mounting holes of the support bracket failed to line up with the bolts they were supposed to match in the gearbox. (That is where the exhaust mount is on the Dyna).
    The mounting instructions were rudimentary. If the instructions had told me to drill out a couple of holes and buy 3 bolts 1/4" longer than the ones already in the Dyna I might still have them.
    I returned them to the retailer and bought a V&H 2-1 at a couple of hundred dollars more. Best money I ever spent even If I am living on beans rice and stale bread for the rest of the month.   <img data-cke-saved-src=      They fitted perfectly without issue.
    Note: Edited for Clarity.
  • punchy
    punchy
    hey shed check out rollies they have a pretty good special running on d&d fatcat for sportsters at the moment
  • punchy
    punchy
  • Sparra
    Sparra
    I have one on my Wideglide..It performs well but the quality of the finnish is not so good...
  • Sparra
    Sparra
    Is that Au$??  I got mine through M & M and it wasn't that expensive but the dollar was a little higher..
    Postage of the patriot pipe is ridiculous. I know as I tried but was cheaper to buy the last stock from an Australian retailer. Would be a lot cheaper if you used one of those third party USA addresses for lease who then forward your post with a variety of post options available
