Online: Soapbox2627
Ipod plug on Ultra harness??????
  • Root Beer
    Root Beer
    A question I picked up the IPod module but ir had no wiring.  If I had the kit, it has a 4 plug harness as part of the kit.  I have found from experience the Ultra Classics seem to have all connecters prewired, rendering the extra harnesses in various kits not needed.  The ittle information I can read about the installation of the IPod module is that as per the CB module there should be a 6 pin female plug already built into the harness.
    If so it is really hidden, somewhere
    Any clues as to where it might be or do I need to try and buy the mossing harness
    Here is the link.  I have the module I do not habe the harness t the left or the long extension for hte ipod
    http://www.harley-davidson.com/store/boom!-audio-ipod-interface
    Thanks
    VIc
  • amills1968
    amills1968
    It is there. Looking at the inside of the dash from the front. It's on the rh side of the cb. You may have to pull it apart and plug the patch loom into it.
  • Root Beer
    Root Beer
    Thanks for the info I took the cb module off and cut the various cable ties to allow better access but unfortunately it remains hidden if it is there. Maybe it isn't fitted to the Australian models :-(
