Online: Stuart, Hilly
Breakout - A Great Machine
  • Bogie
    Bogie
    Had my breakout nearly 3 months... just one great machine.
  • spides666
    spides666
    Yep had mine about seven months now..........got the Bassini short pipes and well personally regretting it.......it coughs and splutters..........had it back to Harley twice and they can't find anything wrong even with Stage 1 fitted...........
  • Bogie
    Bogie
    That's no good.
    It's difficult to compare what's normal and what's not... my breakout backfires when you pull back on the throttle but I like that...have screamin eagle breather and vance and hines pipes... and was told to get a dyno tune when I took it in for it's first service recently but when i looked at what stress the bike goes through getting a dyno tune ... forget it...the way my bike is setup I wouldn't change a thing...
  • Broke
    Broke
    great bike. happy owner. Air conditioned jeans
  • 2015 Breakout
    2015 Breakout
    hey Bogie , ive got the stage 1 aswell and agree its sounds awesome when it backfires after you let off the throttle .
    thinking about stage 4 over the cold winter months but not sure if i should put more kms on her ( only done 2000 kms )
  • Wing Buzzard
    Wing Buzzard
    Hi Bogie i got the same set up mine ran the same until i got it
    dyno tuned now it just screams and sounds shit hot , well worth the money
    you won,t look back.
    Cheers Nick
  • spides666
    spides666
    Mine does it in 1st and 3rd if I push it hard and I far from think it sounds awesome, I think the bike is going to blow up under my legs!!!!
  • sturra
    sturra
    Gday guys. Only new here. Had my BO for about 4 weeks and and done nearly 2000kms. Had air cleaner, short shot exhaust and tuner done when i bought it. The first 800kms were pretty quiet but once i started opening it up the sounds when coming off the throttle are awesome. The crackles, back firing, pops. I love them all. Im new to all this stuff but by having the tuner done after the air cleaner and exhaust do the same dyno tuning?
