Online: speedzter
Trouble with service
  • AlHD48
    AlHD48
    Hi All
    I am doing a service with a sportster 48 and I cant get the T45 torx socket to fit , its a kingcrome 3/8 socket piece ,
    does anyone know what socket set i can buy that will fit ?
  • markwoumla
    markwoumla
    Im only doing this to get my post count up !!!
    Does your torx 45,  look like this !!!!
    yes
  • beaglebasher
    beaglebasher
    to fit what? sump plug? tranny plug? primary plug? if its not fitting try the next size down. if that's too wobbly try an allen key. get a mirror and a torch and have a good look
  • beaglebasher
    beaglebasher
    have a look with the mirror and torch first. my bike has an allen key plug for the engine oil but torx plugs for the others
  • beaglebasher
    beaglebasher
    and while we are here pauly why do you make irrelevant posts with a thumbs up sign? or + 1 answers? I don't get it. you said on another thread you get emails when you get a reply. do you like getting emails or do you just enjoy the little tune your mobile phone makes when you get one?
  • AlHD48
    AlHD48
    Hi all
    It's for the front top engine torx screws, the king chrome tool is too tall
  • AlHD48
    AlHD48
    Hi all
    We'll get a shorter one or 90 deg set like a Allen key or knock the torx tip out of the socket and put a spanner on it
  • AlHD48
    AlHD48
    been difficult to find a short one , thank mark ill get the proxxon ones
