Online: GGUser762
Baffles for V & H Bigshots
  • ralphski
    ralphski
    I have V&H Bigshot pipes on my CVO '08 Springer.
    I find them a little too loud for my liking, like the sound/note though.
    Has anyone fitted quiet baffles to thier pipes?
    Any feedback? part #?, quieter? performance gain/loss? etc. etc.
    Quiet baffles take that "edge" off so they aren't as raspy. Performance wise I was told you actually gain a little oomph due to the increased back pressure, but I can't say I noticed.
  • Retroman
    These are from Khromwerks. Just make sure you get the correct outside V Inside diameter to enable slipping into your V&H Big shot staggered. Available from Rollies in Qld or US ebay
  • ralphski
    ralphski
    i fitted the V & H baffles, done VERY little.
    Also a Screamin Eagle heavy breather.
    Off too get dyno'd now.
  • Retroman
    The khromewerks baffles are well regarded on the US forums after insertion into V&H systems.
    That's where I heard of them.
    The stock "baffles" in the V&H are like cheese graters and are really just a flame trap
