Fuel tap 03 Fatboy
  • Kato
    Kato
    Hi all
    I need to get my fuel tank off the old girl
    It's a carbureted version - not EFI
    I have the factory manual and have followed that to a tee
    after disconnecting the fuel line and then turning the fuel tap on - I get no fuel coming out of the tap
    i have also removed the fuel cap and blew air into the top of the tank thinking this would assist - still no fuel coming out
    i mean I've never had a problem turning the fuel tap on and starting up so why doesn't fuel simply come out of the tap as outlined above
    Any advice would be breath APPRECIATTED as I'm stumped how this is occurring and I need to get the tank removed
  • Hudson76
    Hudson76
    I believe the standard fuel taps are vacuum operated mate. If there is no vacuum, i.e. the engine turning over, then there is no fuel. I'm about to get rid of mine too and put a pingel fuel tap on. which is not vacuum operated. Maybe just siphon the bulk of it out mate. I plan to use as much fuel as possible while riding then siphon the last out before tank removal.
    Hudson is on the money
  • Kato
    Kato
    Dudson was spot on - THANKS for the advice
    a pity i didnt follow up sooner (better late than never i suppose)
