Online: WideglidingNZ, speedzter
replacement shoes for cam chains?
  • Daggs
    Daggs
    I'm after some replacement cam chain tensioner shoes (wear pads) for the primary and secondary cam chains for 07 up engine.
    Tried H.H. but they only sell complete assemblies not the shoes by themselves.
    Can get shoes only from US ebay but does anyone know if they are available locally anywhere?
    Not likely available here.
    The hydraulic tensioners get a bit of a pounding, esp' with high lift cams.
    If they have done enough KM's to wear them out, I would think about replacing the complete assembly.
    Or if they are showing early wear, look into the zippers units for a more stable design.
  • Daggs
    Daggs
    Yeah I would rather buy the zippers dual piston than another set of stock tensioners.
    I am switching to .620 lift cams now too so might be warranted ... What's another few hundred $....
    Then there's probably more clutch work... Gotta love this addiction
    chain are there to replace ,, i always convert to geardrive , fuckdachains, if da cams were far apart i coul;d understand having a chain , but being so close ,     all harleys have been gears for years
