Wider Tire Mods help please
  • Alpha Male
    Alpha Male
    Hi everyone I'm from Perth and I own a 2015 Harley Davidson Street Bob
    I would like to mod the rear tire to fit a 200mm wide tire, would you know who could help me with this and how much will it cost me?
    I cant find anyone in Perth that will customize bikes using Google Search engine as well as this forum search engine.
    Thank you everyone for your informative replies.
  • carbon fibre
    carbon fibre
    Go see the boys at Thundertech in Mundairing or the Wild West boys in Kelmscott
    Google them names
  • punchy
    punchy
    also check out shane at westside customs. pretty comprehensive web-site
  • FatRob
    FatRob
    I put a 200 wide Avon Cobra on my FatBob recently.  Fits easily and plenty of clearance between the tyre and the belt.
    I'd expect your Street Bob to have the same clearance, so as long as your wheel isn't wider than mine it shouldn't be an issue.
    Cheers,
    FatRob
  • beaglebasher
    beaglebasher
    this cunt is a troll
