Online: Stuart, speedzter, Merv
front brake pad replacment 48
  • punchy
    punchy
    g/day fellas. has any one replaced there front pads on 48 with a xr caliper. and what pads are avail and do lyndals do a version for them.
    would like like to try some better pads other than hd type. cheers
  • punchy
    punchy
    cheers stink. will check that out.i knew it was a nissan caliper but didnt think to cross reference some jappas
    looks like lyndal dont do a pad for the xr calipers acording to rollies. be interesting to see what pads others are useĆ­ng  on their xr caliper swap on 48's and iron's
  • punchy
    punchy
    cheers stink and scouser
    checked griffens and they list the same part num for xr and stock 48. harley list different part numbers. 42739-08 for the xr and 42831-04a for the 48
    not sure whether the pads are the same size. checked the local honda dealer and they stock ferodo pads as the genuine pads are over the top price wise
    will keep looking.
  • BAKES
    BAKES
    Interesting, can I assume this is the same for the 08 1200 custom
  • punchy
    punchy
    not unless you've changed the front caliper to an xr 4 spot bakes. is a popular swap for 48,irons and others not happy with the stock front brake.
  • BAKES
    BAKES
    Hey Punchy are you FFF this year
  • punchy
    punchy
    na bakes gotta work .sad
