Online: Stuart
Vic change over reg to WA
  • Canetoad
    Canetoad
    HI All,
    I will be riding and moving to Western Australia from victoria in June and will be due for registration shortly after I arrive..... my questions are:
    will I need to change over my decatted headers and monster oval pipes, because of noise checks?
    does the registration place or roadworthy inspection check your EPA pollution output?  as I have a set of XIED fitted which richens up the mixture
    Is my "all in one" airhorn illegal?
    where is a fair priced HD service shop or person south of perth.
    Thanks for your help in answering these questions.
    Regards Len
  • Retroman
    Mate , you will need "quiet" AKA stock OEM mufflers to pass the pits for your WA rego
    Despite the fact the roads here are full of noisy piped Harleys already already !
    They will not exhaust gas check your bike to check for Catalytic convereters
    Don't know about your airhorn , bring the OEM stocker anyways
    What is your ride ? Some kind of bagger by the sounds ?
  • Canetoad
    Canetoad
    Thanks Retroman!.... and you are quite right as I have a road king.... so you are saying you think I could leave the decatted headers on and only change over monster ovals? that would make things a little easier but if they do a db test the decatted headers make the MO louder so I figure they will do the same for stock pipes!
    as for the horn issue unfortunatley I no longer have a standard horn as a mate needed one for his bike, and at the time I had a spare eh! but thanks for answers your comments were appreciated.
  • Retroman
    Yes mate , you'll be fine with the decatted headers.
    The stock OEM Harley mufflers are quiet as , especially the HDI or "Aussie" spec ones
    If your horn was the stock cowbell thing I probably have one in the shed you could borrow if required
    Just be aware here , you pay for every pits check. Used to be you got " 2 go's" and could go back with "failures" rectified
    Now you pay again for a "re-test"
    WHY WOULD YOU "TIP" THE BASTARDS ??
  • Canetoad
    Canetoad
    Thanks Retroman..... that means I can leave the Monster Ovals on until I settle in and I can change the pipes over myself. And if I need a standard horn I will give you a buzz!
    Thanks again for the help.yes
  • brettm357
    brettm357
    From memory if you keep paying for eastern states rego for another 12 months you can swap to wa without any inspections required as long as you have had a wa living address for at least 12 months
