Online: tussuck
Led rear indicators
  • potluk
    potluk
    Gidday guys I have had  a gutfull of the crappy way that the docking hardware is attatched to my 2014 street bob. why i need to have wires dangling out of my lenses i dont know. i have tried to get around this problem a few different ways with no success. i even waited 6 weeks for the new street bob specially designed relocation kit ( which is a load of shit and i wouldnt bother ) so i am going to attempt to put a tailight on and replace led indicator units with older type bulb ones. My question is has anyone done this if can you help me with wiring and i have heard there is some sort of module that controls the voltage on led,s what do i do with that. Any help would be appreciated. Thanks Potluk
  • Nomada
    Nomada
    I thought that module only add resistance so the flasher works correctly.
    easy to check the voltage with a multimate meter
