Online: tussuck
removal front brake pads flstc
  • jungle007
    jungle007
    Hi guys I'm having trouble getting my front brakes pads out of the calioper on my 2012 Heritage I have the caliper off the the rotor but cannot get the pads out. I have takeken the bolt out which holds the pads in place in the caliper but they will not come out any help would be great.
    Thanks Jim.
  • markwoumla
    markwoumla
    How ya going with those brake pads , Jungle !!!!
    Mate, I've just got back from the pub !!!! No one has answered your post ,, you look a bit lonely there !!!!
    It has got to be something simple ,, google the problem ,, there will be plenty on the net,, you have probably removed he wrong fucking bolt !!!!
    Anyway, I'm going to pour myself a nice Jack ,,, Good luck !!!!
    When you say "bolt". Do you mean two as there is two pin bolts that hold the pads in I thought. Or is there?
