Online: Retroman, GGUser762, Merv
150 tyre on 2001 dyna
  • graeme
    graeme
    this has proberly been done before but has anyone put a 150 tyre on a 2001 dyna if so did you have to modify anything looks like it would fit with some modification to blinker wiring
    I had a 150 tyre on my 2001 dyna I put dome top Allen bolts had the dome inside & the nuts outside as gives more clearance they look better that's about all no improvement in handling or difference in traction at drags as when I wore tyre out I went back to 130 both Avon venom, but as I said looks better 150
  • graeme
    graeme
    Thanks Krash I put the 150 on and did what you said with the bolts no difference to handling and fills the guard out looks heaps better
