Online: Humbug, HD17, John.R, Wanderer57
Light up mirrors on can bus harleys
  • Lodgie
    Lodgie
    Was looking at putting the light up mirrors 92068-08a on my 2014 fatbob. On the harley site it says they fit but just a heads up the wiring is completely different the color codes on the cables and number of cables don't match the loom supplied and the size of the cables and plugs is different. Could probably hard wire them but Definately not a plug and play kit. Gonna see what the dealer says today about it. I think they would look sweet but I ain't keen to go cutting up the wiring on the bike just yet. Also I haven't had much to do with can bus so I don't wanna mess with it too much
  • Lodgie
    Lodgie
    Yeah I was thinking about it but running the multi meter over it but being can bus I was struggling to work it out. It runs on pulses a mate of mine was saying so it's a bit beyond my experience.
  • Havlin
    Havlin
    For what it's worth, I have those mirrors, and I use them as front blinkers instead of running lights (15 FXDB). This enabled me to lose the front OEM blinkers to clean up the front end. The dealership did it prior to delivery. I'm not sure how, and they said it was a bit of dickin' around, but it is do-able. Good luck with it
