Fxd into softail
  • Cromag
    Cromag
    ok, I've got a 05, superglide. And was wondering will my running gear motor tranny etc fit in a softail chassis....why? Well it's something I'm considering, not interested in the you should sell it and buy a x....just curious if it's feasable
  • chriso
    chriso
    Dynas are rubber mounted softails have a balancer in the motor to ease vibration and are bolted straight to frame. complete diffrent setups so not sure how you would mount it in softy frame, would take some work.
    Anything is doable but for me it wouldn't be worth the hassle
  • Cromag
    Cromag
    Thanks Chriso. Damn I miss my old EVO wideglide. Hope you're doing well.
  • chriso
    chriso
    Yeah good mate, where you been? Quite bud.
  • Cromag
    Cromag
    Been around , just quite.....see ya on the road
