Online: Ultramick
Fork Brace
  • Firey
    Firey
    I have a Showa wideglide front end and want to stiffen it up with a fork brace but where the brace is supposed to fit on top of the sliders is conical so the brace won't fit - on top of the sliders measures 69mm and goes down to 65mm. The centre to centre measurement of my brace fits but the Dia of my brace is 65mm
    Can I buy another brace with a 69mm diam for the sliders?   will that be alright?   does anybody have any idea pls
    Regards
    Firey
  • steelo
    steelo
    I've got a deuce. Dont you pry off the conical section, put the brace on at the top of the slider and replace it (the cone) after. Could be wrong
  • Firey
    Firey
    Thanks for the response - Iv'e got an old shovel and it's one piece - all solid
