Online: Hilly, Merv
Chrome Polish rust remover
  • AlHD48
    AlHD48
    Hi All
    Just wondering what the best product is for polishing chrome and light surface rust removal, having trouble figuring out what products to buy.
    Help is appreciated
    Whats your cleaning / care routine ?
    Thanks
  • TC883
    TC883
    Best way to remove light surface rust on chrome is a piece of folded aluminium foil and a bit of water. Works like a charm. Once done, polish the chrome with any good polish such as autosol or McGuier's. TC
  • Outcast
    Outcast
    I had better luck using phosphoric acid & a nylon bristled brush purchased from Bunnings.
    Apply with brush, scrub gently. Continue to refresh the phosphoric acid until rust blemish removed & then rinse thoroughly & polish. Make sure you wear rubber gloves whilst using the acid.
  • AlHD48
    AlHD48
    thanks for the advice guys , does the aluminium foil cause scratches ?
