Online: beaglebasher, John.R
fxr starter problem
  • 666
    666
    92 fxr has a random miss start?will do it one time on a days ride
    Could be multiple things more info needed ,what do you mean by mis start
  • 666
    666
    sorry what imean is starter doesnt engage and makes a loud screech but the next press of the button starts fine maybe the spring on the jackshaft is getting tired?
  • Drac
    Drac
    I have had that issue and it was the starter clutch or bendix or whatever you want to call it.
    yep its da bendix clutch gear by da sound of it
  • 666
    666
    what sort of dollars for parts? do the rest myself, hey daddy been wanting ask you about your dyna what engine mods have youdone?
    use to be around 150-190 bucks you will have to clean da soleinoid out or kit it,i haven't done any its how she came with drop in cams & 45 mic flat slide , racing her this year stock 1999 88 ci stock heads stock pistons, need to aim for 11.00 sec flat in the 1/4 mile
  • Qbob
    Qbob
    I have a starter clutch for $50.00 if that helps. It has part number 400111 on it, which Spyke list as the one for you? I have had it for a long time, but just would never need it. Brand new in a sealed bag in the box. I think it is a Spyke heavy duty type.
    Yep what kiwi said nippion denso ,I just recently used a harley starter solenoid repair kit in my hilux as I had it on the shelf $20 dollar fix instead of $150 rebuilt starter
  • 666
    666
    Ended up being a sus battery but will keep a close eye on the starter
