Online: John.R
Change a flat tyre?
  • tman
    tman
    Hi all,
    I've had a 2003 v-rod for a couple of years and I finally got a flat trye the other day.
    I decided to buy a jack and have a go at getting the rear wheel off myself...
    but I can't even get the V&H pipes off?!?!?
    I've undone the bolts and can wiggle it and see it move but I'm starting to get to the point of worrying that I will break something if try any harder?
    Should I find a block of wood or something and just start bashing it off?
  • tman
    tman
    I fixed it! A good dose of WD40 and off it came with a bit of a wiggle!
