Online: John.R
S&S 106 kit piston valve relief cc's
  • Daggs
    Daggs
    hey,
    does anyone know what size the reliefs are in the pistons in these kits?
    I'll will be measuring mine anyway in a couple of weeks when i pull it down to fit new heads (by Hoody) but just trying to get a jump start in working out compression figures so I can fit the right gaskets.
    I have 30 thou and 40 thou head gaskets just in case but need to measure how much down the hole and this cc volume before i can know for sure.
    shooting for 0.035" - 0.040" squish
    cheers guys
    I've seen a few figures, but if you use -2.5cc you will be close enough until you get a chance to measure everything.
  • Daggs
    Daggs
    Cool thanks mate, yeah I've been doing a few calculations using between -3 and -6 but it's a bit of a waste of time until I measure it properly
