Online: obisteve, John.R
Drag racing
  • fatboyadam
    fatboyadam
    Hi all, stupid question from a newbie so go easy on me.
    So ive been cruising around on my softail for a little while now &  would like some advice on the best way to launch off the mark from you guys with alot more riding experience than me. I usually just take off normally & than open her up. Ive never really known how to (or had the balls to) launch off the line. What is the best way to do it. Can i just drop the clutch at say 4000rpm & will the standard clutch grab?  Thanks guys
  • Soapbox2627
    Soapbox2627
    And your licence will launch off the line with you
  • fatboyadam
    fatboyadam
    So what do you guys recommend then?
    hit da track its only cheak 50 bucks m we have bike night @ Sydney Drag strip once a month or Wed nit's every week car & bike meetings have some fun
  • Smokey61
    Smokey61
    Use about 3500rpm, slip the clutch just enough to get you moving before letting it out fully. Don't bother with burnouts or especially water burnouts. Stage shallow, leave on the last amber. Preload the gearlever with your foot and don't bother with the clutch after the start, just snap the throttle off momentarily and you'll change up. Use the flattracker technique of holding the left fork leg with your left hand and lean as low as you can to reduce drag. That should cover it.
  • fatboyadam
    fatboyadam
    Thanks for the info smokey. Can a standard tranny handle changing up without the clutch?
    On my Sporty if I'm in racing mode I will use the clutch from 1st to 2nd and then go clutchless from there on; and man it makes a massive difference in the distance you gain when compared to using the clutch per normal. Not sure If I'm brave enough to try the same on my old FXR as the transmission is not as smooth as the modern ones.
  • 92Fatboy
    92Fatboy
    Be warned bud drag racing can get addictive , it's also bloody harder than it looks ! Start off slow and build up and the more you do it the quicker you get. My best time was low 10's on a Jap bike , that's pretty slow compared to others but still fun. I think WSID street meet is on tonite $50 for 1/2 dozen runs or so.
  • Ando
    Ando
    I am heading down to the Motoplex tonight for a few run's
