Online: Stuart
Oxygen sensor removal for RWC pipes - Question?
  • Maphew
    Maphew
    Posted this over in the softail section, probably better over here:
    Evening all,
    Running my Night Train in for a RWC (Victoria) this week.
    The V&H Big Radius pipes are obviously too loud, I have been lent a pair of standard softail exhausts without Oxygen sensor ports, the Night Train is EFI and has oxygen sensors.
    I have fitted up the stock pipe and completly disconnected the oxygen sensors, they’re still in the V&H Big Radius pipes.
    The bike will be ridden no more than 5 or so km's for RWC purposes.
    Question, will disconnecting the oxygen sensor cause any major issues?  Will it through a check engine light? Best to leave them connected but tucked away or completly disconnected?
    Thanks for respones.
  • Ando
    Ando
    Open loop all the way
  • Maphew
    Maphew
    Thanks for replies.
    I ended up leaving the oxygen sensors disconnected for the RWC. Didn't throw a check engine light.
    V&H's back on, all good.
    Thanks
