Online: Stuart
Side mount number plate
  • Gary hardman
    Gary hardman
    Iam after a side mount number plate for my 2013 softail. I saw one mounted to a 2014 breakout. the bracket was located and fitted on the blinker mount. the blinker body was shorter to accomodate the number plate braket, so basically both rear blinkers where the same size. I spoke to the guy who had this set up and said he purchased this in the states. Want to know if some thing is available here in Austarlia. The blinker mount was the way to go as you can see the plate from most angles.
  • Knight
    Knight
    try the fender eliminator.
    you can checkout my website www.knightindustries.com.au
