Online: Humbug, Hilly
2014 Street Glide Tow Bars
  • slup
    slup
    Hi, has anybody fitted a tow bar to their 2014 Street Glide if so, can you please help with links where you purchased your tow bar and if possiable some information on your wiring from bike to trailer as i believe you can't just hack into the wiring loom on the 2014 bike. Any help would be much appreciated.
  • grahamjb
    grahamjb
    http://www.openroadoutfitters.com/index.php?main_page=product_info&products_id=441&zenid=fju1gb94oog7ftehsedopogma2
  • slup
    slup
    Thanks mate, went with open road outfitters, looks like a good setup.
  • slup
    slup
    Finally fitted the twobar and the wiring, easy fit and doesn't stand.
  • grahamjb
    grahamjb
    Have you changed the rear shocks from air to a progressive type to cope with the extra load?
  • mickle
    mickle
    I am guessing no need to change shocks, I read some where the tow ball weight is very low.
  • Damo222
    Damo222
    The general rule of thumb seems to be approx. 15kg weight on the tow ball. Give or take a few kg depending on how the combination handles.
  • FXST11
    FXST11
    I bought the tow bar for my FXST from Classic Industries at Yandina on Sunshine Coast. Then bought a Plug & Play wiring kit from Kuryakyn.
  • Rumpig_63
    Rumpig_63
    Would you have a part number for the Kuryakyn plug and play??
  • FXST11
    FXST11
    http://www.amazon.com/Kuryakyn-7672-Trailer-Wiring-Harness/dp/B0050DC640
    Go to Kuryakyn web site as they have diff to suite certain year models,
  • Rumpig_63
    Rumpig_63
    thank you
  • FXST11
    FXST11
    Rumpig, Yeh I have a 2011 FXST, going by all the references. There is None to suite mine. got the 7672, and plugged straight in and working perfect. ( the 7672 has extra couple wires so I could run power into trailer for Cigarette lighter plug USB plug to charge this and run LED camp light ( well to charge it)
  • Rumpig_63
    Rumpig_63
    Thanx FXST11 I have been trying to work out which one might fit so I will give it a go.
