Online: Retroman, Hilly
Engine Mods to 2007 Model's
  • Nige085
    Nige085
    18 years ago
    Gooday!!
    Has anyone done mods to there 07 models???
    I have a 07 Fattie that I have kitted out to 103 Cub  with SE HTTC heads and pistons, SE 258 Cams, SE Hi Flow Air Fliter, SE2 Slipon's running with ThinderMax Auto Tune ECU and Digital Console.
    The best money I spent was on the ThunderMax stuff!! No need to visit ant Dyno's. Tunes automatically on the fly giving the best power and economy!!
     Great HP and Torque, runs nice!!
    Anyone with feedback would be appreciated!!
    Nige085
  • kingchops
    kingchops
    18 years ago
    Nige,
    Welcome to the forum. That sounds like some serious work, most I've done so far are slip-ons. I'm waiting to decide on a fuel tuner to put my high flow AC on, the thundermax sound pretty good though from all that I've heard from yourself and others that have used it.
  • phil
    phil
    18 years ago
    Hi Nige Did you got your bike dynoed if so how much HP and Torque stock is about 68 hp . Had my 07 FSXT dynoed when PC111 installed got 74.5 hp and 89 torque.Thinking of 103 kit . Thanks Phil
  • GREG
    GREG
    18 years ago
    Man, some serious mods. How different does it feel from stock?
  • BACAMICK
    BACAMICK
    18 years ago
    so ur liking ur thunder max ,thats  good to hear , as im way over my pc3
  • kensim
    kensim
    18 years ago
    karlrockdrdrain i am thinking of getting afat cat exhaust did it make much difference.
  • kensim
    kensim
    18 years ago
    139 hp that street bob must get down and boogie
  • Nige085
    Nige085
    18 years ago
    Hi Phil!!
    No I haven't had it Dyno'd yet!! But I guess it won't be long!! Just waiting to fit a SE 50MM Pro Throttle Body to finish off the job!!
    Fitting all the right gear to go with the 103 bore, mate it made a big difference to the performance of my bike!! I would recommend doing that to any  2007 stock 96 cub engine, it's so easy with the longer stroke crank in the late engines to get good power and torque figures!!
    Nige085
  • Nige085
    Nige085
    18 years ago
    Well Thank's for your welcome King!! I hope this forum kicks off and we can all make good use of our common interests!!
    Nige085
  • BACAMICK
    BACAMICK
    18 years ago
    200 in 4th as you hit the limiter
