Online: Stuart
Fat bob bars on wide glide?
  • Rjay
    Rjay
    Hey, anyone know if I can fit fat bob drag bars to my wide glide?  I found this pic on the net and it looks like what I'm after.
    Cheers!
  • Lodgie
    Lodgie
    Yeah might need to change ur cables if u don't want the extra slack in em but in pretty sure they will fit no dramas. Or look at a set of t bars similar height to your current ones if it's just the flat look ur after and u don't wanna change cables
  • pva68
    pva68
    The fat bob and wide glide use the same risers so fitting the bars should be pretty easy. The only drama may be the extra rake angle on the widey may bring the bars slightly lower and there is fuck all room between switches and tank on the fat bob already.
  • Rjay
    Rjay
    Cheers for the reply guys.
    I would be keen to buy a set and try them out if I can get them at the right price. Anyone have a set laying around?
  • shingles
    shingles
    i av a set with standard black risers and cables 4 throttle and clutch as new 1/14 inch same as your looking 4 with riser bolts $200 bars an risers and risers unchipped black coating plus riser cap unchipped coating from new im in qld u will av 2 pay frieght which is not much aus post sending method risers in box styrafoam recesses as not 2 damage black coating my ph. con.0406369142 i bought bars an risers 2 change 2 fatboy style just on 600 buks so my parts very reasonably priced
