Online: Soapbox2627
Breakout,Street Bob or Wide Glide
  • DylanH237
    DylanH237
    Hi guys,
    I'm new to the forum and was wanting to get your opinions on these bikes.I've been riding sports bikes for the past few years and was wanting to make the switch to a HD.I really like the Breakout but my issue is it's low lean angle.I don't want to be scraping the pegs on every tight corner.I know you have to pick your speed into corners more carefully but does it really affect how you ride the bike compared to the other two?I don't mind the looks of the Street Bob but would prefer forward controls over the mids.I know you can get them changed though.Any advice would be grealty appreciated.
    Thanks,
    Dylan
  • FLIPDOG
    FLIPDOG
    it wont have to be a tight corner to scrape the Breakout pegs you'll do that on round-abouts
    as you have a sportsbike history the dyna series will suit you must likely===they handle /corner better
    get yaself to a stealership and go for a fang on the models your interested in and some your not even
    then buy private with the aftermarket bits already done
