STATOR SCREWS
  • DUGE
    DUGE
     Hi Fellas
    Got a new stator and rotor coming.
    The manual that I have says dispose of the stator screws and use new ones, so I phoned up the shop, they said nobody does. They never got back to me.
    Any views?
    Thanks Duge
  • noctm
    noctm
    It's best practise but is not something I would worry about personally. If you have the screws change em, if you don't and can't be fucked getting some then don't worry about it.
    Though that being said I would make a judgement based off the condition of the screws. If they look like they're in good nick then I'd re-use them making sure I use a bit of loctite as well. Some people say use the strong stuff in this application - I do not agree, I use the blue loctite in this situation.
    For the price, I use new screws.
    They are small and have quite a high torque spec.
    I'm sure you could re-use them and be OK though.
    I've also heard of some people re-using O-rings to save a few $$ !!
    Screws are okay with loctite but never reuse the 'o' ring, 90% of the time they leak.
  • DUGE
    DUGE
    Hi
    Thanks, I figured as much. I rang the shop back, same answer, week and a half to order the screws. Think if it was imperitive they would include them with the new stator.
    Cheers Duge
  • DUGE
    DUGE
    Hi
    Update on the screw debarkle. Stator turned up today Cycle Electric. Screws in the box, go figure. Two phone calls and worry for nothing.
    Cheers Duge
