Online: Merv
Wide glide rear fender tidy up
  • malex
    malex
    gday New to the forum and didnt have much luck with the search. Has anyone tidied up the rear fender on a newer wideglide so its more like the US version without the big brake light? I believe the indicators have the brake lights built in? Im chasing photos/part numbers/prices/ideas Have heard you can just order the US rear fender ($$$?) and a set of Breakout integrated Indicator/brake lights ($$$?) OR is it possible to just remove the existing brake light off the aussie fender or will there be a big ugly hole? Thanks in advance cheers
  • Longy2018
    Longy2018
    Pretty much what you said... Removing it leaves an ugly hole, you can get the US fender and breakout or softail slim tail/indicators  or you can run the led edge tail light they make for our fender ($110) not too sure on prices for the rest of it... I've just painted my donkey dick black for now, looks better than chrome and will do for now but will have to tidy it up soon.
  • FXDWG 103 SE
    FXDWG 103 SE
    I have the new denim wide glide so I'm keen to see what you do. I do like the break out lights. Side mount the number plate and replace the guard. That's just the trick I'd reckon.
