Online: beaglebasher, John.R
enginge light
  • sedgez900
    sedgez900
    hi out there i have 2000 model wideglide engine light stays on what happens is turn ignition on light comes   then gos off start bike then 5 seconds comes on again and stays on any help would b great
  • steelo
    steelo
    Not meaning to drag you off to another forum but a Google search has plenty of results. Is the bike EFI?
    If so, check this link
    http://www.hdforums.com/forum/dyna-glide-models/337169-04-dyna-wide-glide-check-engine-light-comes-on.html
    Some other options are plugs, loose battery terminals
  • Drac
    Drac
    Oil light? No efi on that model.
  • sedgez900
    sedgez900
    That would b fine but I know difference between engine and oil light
  • taff60
    taff60
    have you checked it for fault codes?
