Online: beaglebasher, John.R
Fitting 150 tyre on chain drive 1200
  • judgelj
    judgelj
    So i'm about to order my new commander 2 tyres in a 130 rear, though i was hoping i could fit a 150. I check swingarm cleaerence, which is fine. Though i noticed the chain is currently approx 1cm from the existing 130 tyre. Can i correct this by spacing the sprocket forward with washers/spacers? Has anyone got any expirience with this?
  • judgelj
    judgelj
    The other thing is that i'm planning on running burley slammer shocks. If i successfully spaced the sprockets, would the 150 tyre foul on my fender?
