Online: B0nes
Just found this polish/wax/cleaner company in Melbourne
    Just came accross this place by dumb luck and think I'll give them a try.  I have no idea if they are any good, BUT the range of products they have is awesome!
    http://www.waxit.com.au/
  • Krackers60
    Krackers60
    Looking forward to seeing your comments on these products.
    What are you currently using?
  • FLIPDOG
    FLIPDOG
    You'll have to give us all the full review after you've tried them, comparing to other products
    Be honest now
  • Soapbox2627
    Soapbox2627
    I ordered a couple bottles of the crystal spray on stuff, the wife thinks it looks ok so for $70 buck, how bad can it be?
  • TJU
    TJU
    Keep us informed of the good or bad qualities of the product guys , sounds interesting .
  • Tat2_u
    Tat2_u
    I just had a look at the products they have I hope you have a thick wallet
    after buying there products you wont have for long
    be interesting to read your review
    OMG....I'm not keen to start yet another detailing thread! I recon everyone has their personal preference as to what polish or wax they use.
    I am excited to see that the site stocks some of the more exotic brands that you cannot get down at the local store - I'm checking out metal sealers at the moment to see if I can protect all the raw polished aluminum on my bikes. I think I'll buy a bottle of the Wolfgang stuff cause it sounds good...lol
  • Tat2_u
    Tat2_u
    Tussuck was looking at that also Just gotta wait till its back in stock
    and some spray on wax as they do colour coded stuff which was not to bad on price
