Online: Stuart
Hand Grips? Which ones and why?
  • ride511
    ride511
    I have a 2015 Streetglide and will be putting on new bars. I want to move up from the stock rubber grips.
    I have considered the streamliner, slipstream and countour custom. Any suggestions?
    I changed to a chrome and rubber ribbed grip but went back to the oem rubber ones as they're more comfortable particularly on long rides.
  • Independant_84
    Independant_84
    I changed to a soft foam covered in leather 1" longer then stock.
    Because i find them more comfortable and the stock width grips are tiny .
  • Tat2_u
    Tat2_u
    Iso grips cause my hands are fucked super comfortable and I can ride long distances
  • Tat2_u
    Tat2_u
    double post i hate that
  • Deadwood
    Deadwood
    I've got the Slipstream grips and quite like them, wasn't a fan of the ISO grips.
    Got a decent interstate ride coming up so I'll know more about them after that ride I guys
  • Troyg150
    Troyg150
    Performance Machine Contour grips, best I've had
